Fortnite Battle Royale Lag Fix Guide
Posted by Test Engineer at Netduma
18 Jun
Top 10 Tips to fix Fortnite Battle Royale Lag
Fortnite Lag Fix Guide
Fortnite Lag can spoil your chances of getting a victory royale, and make your gaming experience a whole lot less fun.
This guide will cover the best ways to fix Fortnite lag using the tools at your disposal.
 Top 10 Fortnite Lag Fix Tips:
1. Check Server Status
2. Wired vs Wireless
3. Monitor vs TV
4. Check Console/PC Spec
5. Wired Controller vs Wireless Controller
6. Lower your Base Ping
7. Distance
8. Bandwidth and Local Congestion
9. Port Forwarding/Open NAT
10. Internet Service Provider
Occasionally the game servers themselves will be at fault so this is the first thing to check. Fortunately Epic Games keep players informed through Twitter and their website.
What you need to do:
A. Check the status of your online network:
Xbox Live Status
Playstation Network Status
B. Check the status of the Fortnite servers:
Fortnite Status
If everything seems fine then move onto the next tip.
wired vs wifi gaming netduma
Despite what you may have been told, playing on WiFi is NEVER good for gaming. It can be unstable and cause lag spikes, packet loss, jitter etc – basically it can cause a whole heap of headaches. So if you are serious about reducing Fortnite lag then playing on a wired connection is an essential step.
A. If you are playing on Wifi, switch to wired connection. Connect an ethernet cable from your console / PC to your router. If the two are far apart you can buy long ethernet cables (some are as long as 100 metres) to link the two.
If you can’t run a cable between them then look into Powerline adapters, which is a very clever gadget that allows you to use your home’s electrical wiring to transport an ethernet connection around your household. Just plug one end into a plug socket near your router and the other in a socket near your console and you’re good to go. Magic. Check them out:
Powerline Adapters (Amazon UK)
Powerline Adapters (Amazon US)
B. If you HAVE to play wirelessly then there are a few things you can do to improve it’s reliability:
– Connect to your router’s 2.4GHz frequency instead of 5GHz as it is more stable. All wireless routers have a 2.4GHZ frequency. If you are not sure which frequency you are connected to then check your router’s WiFi settings.
– Use a WiFi analyser to find the least congested channel in your area and then change to that in your router’s WiFi settings. How to find the least congested channel in your area.
A. If you’re already playing wired then you may want to switch out your ethernet cables as they can degrade and become faulty over time.
3. Monitor > TV
Fortnite has the option to run at 60FPS (‘frames per second’) on consoles & even higher on PCs. If your screen can only display 30FPS then you’re going to have big issues when using this mode because your screen literally can’t show you the game fast enough.
TVs render much more slowly than monitors, so whilst the idea of a widescreen TV may seem like a good idea, it’s actually one of the biggest mistakes you can make for gaming.
A. Get a monitor that has, at the very least, a 60Hz refresh rate. It will also need a low response time, 1-2ms is ideal. That’s the delay between the action being executed and being shown on your screen. Here are some recommended monitors:
Asus VG248QE
BenQ Zowie RL2455
B. If you’re only able to use a TV see if it has a ‘Gaming mode’. Monitors usually also have this setting as well.
If your console’s hard drive is full of games/applications it can run sluggishly. And if you’re playing on a PC then it needs to have a good enough specification in order to handle the game.
Console
A. Delete some of the games/applications on the hard drive to free up space. On Xbox One in particular if you’re experiencing occasional stuttering then clearing your local saved games can help.
B. Some players have had a great deal of success by replacing the built in hard drives with SSDs (a much faster storage device than traditional hard drives) as they rapidly speed up loading times. A Google search will throw up several options.
PC
Make sure that your system requirements are up to scratch if you’re playing Fortnite on a PC. Low-end PC’s will struggle to run the game to its full potential, causing issues such as rendering difficulties / slow-downs and low frame-rates.
Consult the table below to see the minimum system requirements for Fortnite:
Processor Core i5 2.8Ghz
Memory 8GB
Graphics Nvidia GTX 970 / AMD R9 390 or above
Storage 20GB
OS Windows 10 64-bit
Mobile
If you’re playing on a mobile you need to ensure your phone is compatible. Fortnite on Mobile requires an internet connection and iOS 11. Currently the only compatible smartphones are: iPhone SE, 6S, 7, 8, X; iPad Mini 4, Air 2, 2017, Pro.
Fortnite is not supported on: iPhone 5S, 6, 6 Plus; iPad Air, Mini 2, Mini 3, iPod Touch.
5. Wired Controller > Wireless Controller
Did you know playing with a wireless controller can cause input lag? This is the delay between you pressing a button and the console responding. It’s often caused by interference from other wireless devices in the vicinity. Fortnite Pros don’t use wireless controllers for a reason.
A. Use a wired controller or if playing on a PC, a wired mouse and keyboard. If you have the budget, you may want to invest in a custom controller e.g. a Scuf.
Your ‘Base Ping’ is a measure of the time it takes for you to reach the nearest Internet server to your home. If you live in a remote area, such as the countryside, your base ping will probably be higher than someone who lives in a city. Base ping matters because it is a delay that you always have when gaming. For example, if you have a base ping of 30ms then your game ping will never be lower than 30ms. So having a high base ping will mean you will always be experiencing some lag in Fortnite and other games.
A. We recommend using a program called Ping Plotter or utilising the internet diagnostics on the Netduma router to find out the quality of your internet connection. If your base ping is lower than 30ms then you’re fine, otherwise it’s worth contacting your internet service provider to see if they are able to resolve this.
Just remember that there may be nothing they can do if you live in a remote location.
7. Distance
Now we reach the NUMBER ONE cause of Fortnite lag – the distance from your home to the server of your game.
When you are put on a server far away from you then you will experience lag. It’s just like real life; the further you have to travel the longer it takes. Games packets are no different. What’s worse; other players in the game who are located nearer the server will have an advantage over you as they will have a lower ping, making their experience much more responsive.
Every time you enter a Fortnite lobby you are connecting to a server somewhere in the world. This dedicated server is dependent on which region you have chosen in Fortnite.
A. To select your region in Fortnite, open the main menu of the game.
Click the gear icon to open the settings menu.
Select the tab with the gear icon to open the game settings.
Under Region, you should see an option labeled Matchmaking Region. Select your region. If you are unsure, select the region with the lowest ping (in ms).
B. The best way to counter Fortnite lag is by always playing on the closest server in your region, and we have the only solution to this massive problem.
Most Fortnite regions have several game servers within them. An example of this is the European region, which has three servers in Ireland, London and Germany. The game will connect you to any one of these servers if you have selected Europe as your region.
If you live in London, the German server would give you a worse ping than the London server due to the distance. Using the Geo-Filter, you can exclude the Irish and German servers, thereby connecting to the London server and giving you the best connection possible. This method works for all available Fortnite regions, and will give you faster response times and fairer gameplay.
Watch it in action on the Nighthawk XR500 here:
You can order a Netduma R1 from this link. Use the code ‘Fortnite Lag’ for 5% off.
We are also in partnership with Netgear and the same capabilities are available now on the greatest gaming router ever made, the Nighthawk XR500. Find out more here.
C. If you are not able to invest in a new gaming router then your next best option is to leave the Fortnite matches that are playing particularly poorly. It’s not ideal but hopefully you will have better luck with your next game.
Have you or a friend ever bragged:
“I’ve just upgraded my Internet speed to X billion megabits per second so I’m now going to be unstoppable online”?
If so, your or your friend have fallen for one of the biggest myths in gaming. High bandwidth speeds do not mean you will have a faster gaming connection.
The truth is games only need a little bandwidth, usually less than 0.5mbps, which most homes have. When it comes to bandwidth speeds what actually matters is congestion on your line, which is caused by other people in your home when they hog the bandwidth, such as streaming an HD film or torrenting. This creates gridlock on your Internet connection and will cause your game to lag significantly.
A. Most routers have a feature called ‘QoS’, which is designed to prioritise the traffic on your network, e.g. gaming over other applications, and / or eliminate congestion. But most routers do a very poor job of this as they rely on technology that is over very dated and ineffective.
At Netduma we invented a unique algorithm that will totally eliminate all congestion, meaning you can game whilst everyone else uses the Internet as much as they need to. Check out a demo of this in action:
You can order a Netduma from this link. Use the code ‘Fortnite‘ for 5% off
B. If you are not able to invest in a Netduma then your next best option is putting on your best begging face and ask the guilty party to stop hogging all the bandwidth.
You can have connection issues if the ports required for the game are not open, meaning you don’t have an ‘Open NAT’. A strict or moderate NAT can cause you to be unable to connect to other players online.
NAT Table Console
A. Check your NAT status. Do this by going to the network settings on your console. For PC players the game itself will tell you this information.
B. If you do not have an open NAT then you should enable ‘UPnP’ enabled on your router. This will automatically open the necessary ports for you. If you still don’t have an open NAT after trying this then then you can manually port forward yourself. Just make sure to do one or the other. Activating both can result in conflicts. See these guides:
Port forwarding guide
Opening your NAT with the Netduma R1 Gaming Router
10. Internet Service Provider (ISP)
Finally, if you have tried everything else in this guide and you’ve still got Fortnite lag then it’s likely that poor service from your ISP is the cause. If your ISP is oversubscribed in your area you may experience packet loss during peak times e.g. evenings & weekends, and sometimes errors on your line can cause your connection to the game to be unstable.
A. If you’ve followed everything in this guide & you’re still experiencing consistent/significant lag then you should consider finding an ISP that has better connectivity options available for your area. A smaller ISP is likely to be under subscribed, thus leading to a better connection and better customer service if required. If you have a Netduma router you can follow this guide to do a test on your network. Alternatively see here for a guide on using Ping Plotter.
That’s the end of our Fortnite lag fix guide. We hope it has helped you to solve your lag issues. If you are interested in buying a Netduma to crush your lag then you can use code “Fortnite” at checkout for 5% off!
