How to Fix High Ping and Lag in Fortnite (2026)
December 2, 2025
With so many game modes in Fortnite, one thing remains the same – lag sucks. Whether you're playing Battle Royale, OG, or Zero Build, a bad connection can ruin your gameplay.
In this blog, we’ve got solutions for all networking issues in Fortnite, including high ping, packet loss, and unstable connections. Let’s start optimizing your connection for the best possible gaming experience.
In-Game Settings to Monitor Your Connection
Fortnite includes built-in settings to diagnose your connection issues.
Enable Net Debug Stats
The first setting to enable is “Net Debug Stats” in the UI menu. This displays your ping and packet loss in real time, helping you identify what’s causing lag.
Most players can feel when something is off, but this setting provides real-time stats to pinpoint whether your ping is spiking or you’re experiencing packet loss.
Set Your Matchmaking Region
The next crucial setting is your “Matchmaking Region” in the main settings menu. To get the lowest ping possible, set this to Auto or manually choose the region with the lowest ping.
Since ping is determined by the distance between your device and Fortnite’s servers, always select the closest region to minimize lag.
Check Fortnite Server Status
Sometimes, lag isn’t your fault – it’s due to server issues. To check if Fortnite’s servers are having problems:
During peak times, high server traffic can lead to lag. If servers are experiencing problems, there’s nothing you can do but wait.
Use a Wired Connection for Stability
A simple but game-changing fix is switching from Wi-Fi to a wired (Ethernet) connection.
Why Ethernet is Better for Fortnite:
  • More Stable Connection – No signal interference or drops.
  • Lower Ping – Data travels faster with a direct connection.
  • No Packet Loss – Ensures consistent, real-time gameplay.
If you can’t run an Ethernet cable, consider Powerline Adapters, which use your home's electrical wiring to create a wired connection between your router and gaming setup. They offer better stability than Wi-Fi, though slightly slower speeds than a traditional ethernet cable.
Optimize Your Connection with the Netduma R3 Gaming Router
If you’re still experiencing high ping, packet loss, or lag, it’s time to fully optimize your network with the Netduma R3 gaming router. Our router comes with powerful gaming-specific features to eliminate lag once and for all.
Connect to the Best Fortnite Servers with the Geo-Filter
The Geo-Filter lets you select the exact Fortnite server you connect to, ensuring you always get the lowest ping. Even if you’ve selected a low-ping matchmaking region, Fortnite may still connect you to far-away servers within that region. The Geo-Filter guarantees you only connect to the best servers every match.
How to Set Up the Geo-Filter:
  • Connect your gaming device to the Netduma R3 router.
  • Open the Geo-Filter and add your device.
  • Set your filter radius to only include the lowest-ping servers.
To find the best Fortnite servers to include in your filter, use Ping Heatmap, another feature of the Netduma R3. Simply select Fortnite, and you’ll see a real-time map of server locations with their ping values.
We have an ultimate Geo-Filter guide that shows everything you can do with the feature. Check it out here.
Stabilize Your Ping with Steady Ping
A stable ping is just as important as a low ping. The Steady Ping feature on the Netduma R3 smooths out fluctuations, reducing jitter and ensuring smooth and responsive gameplay.
How to Enable Steady Ping:
  • Enable Steady Ping from the Geo-Filter interface.
  • Choose Simple Mode for automatic stabilization.
  • Use Expert Mode for advanced tuning options.
Once enabled, your ping graph in the Geo-Filter sidebar will show your new, stabilized connection.
Prevent Lag from Other Devices with SmartBOOST
If other people on your network are streaming, downloading, or using bandwidth, it can slow down your Fortnite connection. The SmartBOOST feature on the Netduma R3 automatically prioritizes gaming traffic, preventing lag caused by network congestion.
How SmartBOOST Fixes Fortnite Lag:
  • Prioritizes gaming traffic over streaming and downloads.
  • Stops bufferbloat, preventing slowdowns during peak usage.
  • Ensures smooth gameplay, no matter how busy your network is.
If you want to see SmartBOOST in action, check out our live demo video here.
Thanks for reading
By following these steps, you should see a significant improvement in your Fortnite connection, including lower ping, less lag, and a more stable connection.
Quick Recap:
  • ✅ Enable Net Debug Stats to diagnose lag issues.
  • ✅ Set Matchmaking Region to the lowest-ping server.
  • ✅ Check Fortnite server status to rule out external issues.
  • ✅ Use an Ethernet connection or Powerline Adapters for stability.
  • ✅ Optimize your network with the Netduma R3.
If you're serious about fixing Fortnite lag for good, check out the Netduma R3 gaming router and its other powerful gaming features.
